Real time help..please
Oh Greats Gods oh the 80..please hear my cries...
Jumped in my '94 80 to go pick up the kid, and it started just fine...like it always does. I few lights came on, AT OIL Temp, battery gauge went on, and check oil. Pulled over right out side my driveway, turned it off, went to turn it back on and now it just tries to turn over with nothing else happening? No drips, all hoses replaced not too long ago. Radio is good, windows work fine. Running great, until now.
Battery, Starter, Alternator....?
Any direction would be helpful and much appreciated.
It's difficult to check alternator without removing it from the vehicle. I would start with the fan belts - are all the belts in place? Next check the battery for proper voltage. Next check all the wiring connectors, especially the main engine wiring harness for breakage or loose connectors.
So everything seems to normal, Checked the wiring connectors and all looked on good condition for the age of the truck. Cleaned the battery terminals....same.
Check your fuses, make sure you have oil in the truck, check your coolant, etc.
You can manually get your rig out of park by putting a pencil or a screwdriver into the small cap-covered slot to the left-top of your shift console. You can push down and manually override the shift lock solenoid and put it into drive.
Good luck.
-o-
Somebody correct me, but isn't the "christmas tree" warning lights a sign of poor voltage and points to alternator issues.
Thanks for the tip on the shift lock solenoid, I got it off the street.
Just out of curiosity, can't you do the old Chevy method of checking the alternator? By that I mean turn the truck on, and in park, while running, disconnect the battery cable. If the car stalled (shut off) then that mean that the alternator was bad. Not sure if you can do that with the LC's though.
This is what I did to one of my cars before. But someone on here told me its not good for the electrical system.:rolleyes:
