Man, I am not having the best of luck with this thing...
This thread describes most of the problem I'm having. I experienced the "instant power loss" when I tried to turn over the motor. It has done this twice before, only to suddenly work again within the hour.
This time, it decided to be stubborn. I went out of town for the weekend with friends, and when I got home, it still hadn't budged. Because it's being so stubborn, I decided to do a little investigating.
I'm no good at explaining, so I will list the things I did. Here goes:
1. Get home, open hood, took a multimeter to the battery. Reads 4.1v (four<point>one
2. Attach jumper cables, charged battery for a bit. MM reads 14.4v with cables attached.
3. Detach cables, voltage drops to 5v within 3 seconds.
4. Remove main Aux. light and stereo system fuses (100A and 40A Maxi)
5. Reattach jumper cables to '+' post and engine hook. MM reads 14.4v
6. Continue to charge battery.
7. Check fusible links, fuses, 'Main' link inside fuse block. All good
8. Still charging. MM reads 14.4v
9. Detach jumper cables, battery settles on 12.4v (cold night)
10. Open passenger door, voltage immediately begins to drop, lights visibly dimming. Close door. voltage creeps slightly up
11. Reattach jumper cables, let battery charge again.
12. Attempt to start truck. Slow cranking, but then fires. Shaky idling at ~350-400 RPM (suspected moisture in dizzy cap, similar behavior. it revved to 700 just fine)
Ok. Now here is the confusing part: When the truck was running, it seemed as though it was pulling power straight off the alternator...Like the battery wasn't even connected. And yes, I know that's a bad thing to do.
There's very minimal corrosion on the positive terminal, barely shows up, but I seriously doubt it would drain the battery that fast. The battery is less than a year old and the alternator is nearly brand new (OEM).
And I have never had any problems with my aux. lights/stereo system drawing excessive current. Each system runs off 2 main 4 AWG cables, which are both fused at the battery, all connections are crimped/bolted/fused and heat-shrinked.
I'm totally and completely baffled. This is my DD. Both parents have their own cars, and are gone 7am-6pm every day.
Any help is appreciated!! Tomorrow is my only day off this week...
-Lane
-Lane
