real time help needed - brake bleed
Denver, CO
Hey guys...took the day off to remedy my brakes. Put on the new-used caliper (thanks Oleg!) and the new pads on both rears. Hooked up the handy little vacuum bottle from Harbor Freight that Romer suggested. No fluid at the rear at first, the dead caliper leaked all night, but after using the pump and also pumping the pedal, I got good fluid...for about 2 minutes, then it was mostly air with a little fluid mixed in. Went through 1 big bottle of brake fluid, alternating the pump and using the pedal, even started the truck and pumped the pedal. Still mostly air at the right rear tire. Is it supposed to take this long to fill the system with fluid, and go through 1 1/2 big bottles and still get mostly air? I don't see any leaks anywhere in the system. Let me know what you think, and if you can drop by SE Denver.
I am calling you right now, Romer! Thanks.
Timm
I just bled mine the good ol fashioned way night before last (friend in the truck on the pedal, me underneath the truck) whole system had been empty for months. Filled and bled about 1 large bottle. Gonna repeat in case of moisture. FWIW
Sounds to me like the system is sucking in air, esp. if your getting good fluid. Did you replace the leaky caliper before trying to bleed? To check for a leak, tighten everything up-then put some pressure on it, ie. pump up the brakes for a bit then look at ALL the fittings and booster/cylinders/calipers.
Hope this helps, I'm sure the gurus will chime in soon as well
gravity bleed the caliper...open the bleeder valve and hold caliper laying flat tapping on the side to force the air out...make sure the caliper is lower than the feeder line....once the air bubbles are out then bleed conventional...
I think my compressor sucks...or does not suck enough. Bleeding the old fashioned way worked. :) Thanks guys,
Timm
