Real Time Help - Birf Disassembly
NSW, Australia
Yeh, sure, I read the FAQ and have a printed copy in front of me. I read it from start to finish 3 times before starting the job.
Now, it says, "dis-assemble the birf from the axle" in post #14. I have not found any instruction on how this is done. I presumed that since it wasn't written up, that it may have been trivial.
I need to replace the birf (or cv as we called them in oz). It has been cluncking badly, and I have the new ones here - but how the f do you get the axle off.
It looks as though there is a circlip in the middle of the spline. I read somewhere that you belt the $%^ out of it with a rubber mallet, busting the circlip, but how do you get a new one back in???
Are there any instructions on the forums on dis/re-assemble the birf to axle?
Pipe method works sweet. Remember to put a rag or something wadded in the bottom of the pipe, else you're going to bash the axle tip on the floor. Also, note the orientation of the birfield star on the one you're removing so you assemble the new ones correctly - they can be assembled wrong. No worries of course if the new ones are preassembled - that's cheating! Be sure to use new clips when sliding the new birfs onto the axles.
DougM
In the end, I chickened out and didn't seperate my birfs (but I also had no clicking, sounds, or problems - just pure PM for me). However, TrunkMonkey offered this fantastic tip for getting the circlip back in place easily and correctly:
Separate with the pipe, when putting it back together, zip tie the c-clip tight, slide it into the birf. The zip tie holds the c-clip compressed and slides off once it's in the birf.
The entire thread is here if you want to read it, but the key info is that shown above.
Good Luck!
The pipe method works for everyone- but me. :D I tried it with a piece of ABS a few times, but I didn't like the feeling I was getting- felt like I was abusing my parts. I went back to my old method- clamp the axle in a vise with the birf hanging down, drive the 'star' off the axle splines with a brass drift. The trick is moderate force and a constant pressure on the drift to keep it from bouncing. The snap ring will compress and let the birf slide right off the axle. I've never damaged the snap ring. For me it's fast and easy, although I've heard of other people that weren't successful this way. To each their own I guess, or my personal favorite- 'Whatever works'. :D
-Spike
