Real Time Help.... Battery Isolator
CouleeDamWA, BoiseID
Ok... I have everything ready to go back in... The only issue I am having is one wire.... which should be simple but my brain is dead.....
I am using a Stinger SGP38 isolator as a simple means for dual batteries.
Here are the stinger instructions.
SGP38 / SGP32 / SR80 / SR200 Installation Instructions
Two Large Terminals:
1 Connect one large terminal to the vehicle's main battery via a fuse holder
2 Connect the other large terminal to the sound system's auxiliary battery batteries, again, via a fuse holder. Note: The large terminals can be wired in either direction
Two Small Terminals:
1 Connect one small terminal to true ignition power from your ignition harness. True ignition will keep power through the cranking cycle of the starter when tested. Verify that your power source is true ignition.
2 Connect to chassis ground. Note The small terminals can be wired in either direction
Wouldnt you actually connect the charging cable rather then the wire from the ignition switch?
No, it's a plain vanilla solenoid. The main battery is being charged via its original alternator output connection, and it's paralleling the aux. when the vehicle is running (ie when the keyed-on ignition is hot). So one small post will be your solenoid trigger, the other small most will be tied to ground. Your keyed-on source is powering the solenoid coil which then connects your main battery to your aux. battery thus facilitating charging...or equalizing. Let me qualify this by saying this how many solenoid work, but specifically a Stinger solenoid....no personal experience so look at the wiring diagram just to verify that what I'm telling you jives.
No, it's plain vanilla solenoid. The main battery is being charged via its original alternator output connection, and it's paralleling the aux. when the vehicle is running (ie when the keyed-on ignition is hot). So one small post will be your solenoid trigger, the other small most will be tied to ground. You keyed-on source is powering the solenoid coil which then connects your main battery to your aux. battery thus facilitating charging...or equalizing.
ok... i was hoping it was something like that..... now i can finish everything...
thanks bro... :grinpimp::beer:
Mobi I know your a knowledable guy n this dept. I'm planning on this same setup. Stinger offers this in an 80, 200, and 500 amp versions. Are any if these insuficiant for the job. Planning on a winch with this setup.
Also, do you have any concerns with using just a simple solinoid for this job?
