First of all thanks to those of you that posted in my other thread asking about the "Tube Sub Assembly" on my 87, 2wd, EFI, minitruck. All your advice was very helpful. I have since after lots of looking found a new fuel pump bracket at a junkyard in CO and he shipped it to my door for 50 bucks. I took the bed off as you all described, got the old bracket off.... didn't even break the rusty screws.
Now my question is: On the new bracket, he sent the high pressure flex line along with it so I got a new one of those. Now I need to disconnect the old one from the metal fuel line. A while back the guy I bought the truck from had the metal fuel line replaced with a rubber one for most of the way. However there is still a foot or so left of the metal line right where it hooks to the high pressure line. Is there a different way to hook it up? Is there a fitting or adapter or anything I can hook to my new high pressure line and take that right into the rubber line? I'm ready to hook up the new bracket but can't get the little hunk of hard line unscrewed from the old high pressure line. Hope I've explained this clearly. If not I'll try and get a picture
How it was hooked up before:
bracket -> high pressure flex line - > screwed to metal fuel line (only like 12 inches of actual metal fuel line) - > Rubber fuel line with hose clamps - > engine
Can I go :
bracket -> high pressure line -> rubber line? (or any other solution so I don't ABSOLUTELY need that metal line with the screw end on it?)
Thanks guys, I might actually get this thing back running thanks to you guys.
Matt
Can I go :
Matt
