Real time Birf Help
Colorado
I'm in the middle of servicing the front axle on my '96...I'm confused (god I hate being a new'b) on the trunion bearings and whether or not they get the Moly Grease (ValveSynth) used in the knuckle or the same bearing grease (Pennzoil Red 707L) that is used for the main wheel bearings...the FAQ didn't seem to cover that detail. I'm ASSuming that it should be the same grease that's being used in the knuckle since it looks like they will mix together anyway...just wanted to double check to be sure...
Thanks in advance for any help...
I asked a similar question once. I think the answer I received was you should use wheel bearing greese for the trunion bearings. I remember this being the answer because I too thought you should use the moly stuff since it will mix anyways. Probably shouldn't make a huge difference if they mix together, I dont think the trunion bearings see that much action anyways.
It's true they do mix, I used the synthetic mobile 1 (red stuff) because it's probably the best for bearings. You're getting the job done, not waiting, that is what's important.
Thanks for the input...I'll probably use the same grease as the knuckles sisce they'll mix anyway and like you guys said, it's not like they see high speed, high temp action. It's been killing me watching it sit and not be able to drive it because I knew the birfs were WAY past due. It looks like I got to it in time...what a mess! 143K worth of birf grease all over the place. The drivers side wasn't as soupy as the passenger side which was pure liquid. One of the trunions had a nice gash in one of the rollers but luckly it didn't scar anything else.
The job is pretty straight forward ( thanks to the FAQ and all who's contributed on the subject)...I've been spending a majority of the time cleaning all the grease off of everything!
Thanks again...:beer::beer::beer::beer::beer::beer:
yeah cleaning stuff properly takes a great deal of time. I was careful not to leave any degreaser on the birfs as i figured it would lead to early grease breakdown.
