- Joined
- Dec 17, 2006
- Threads
- 63
- Messages
- 886
- Location
- Central Coast, CA
- Website
- www.coastal-aquariums.com
I heard a squeel from the hood on the way home and thought it was a loose belt. It may have been, but the bigger problem was the belt that was hanging loose! It was off of the pulleys and actually stuck in between a bolt and some metal to the lower left.
I followed the path of the belt and I can't tell which belt it is. All of the pulleys have belts around them. The pulley coming off of the fan has two belts on it. It is this front belt that is off the track. I cut it out because about 25% of the teeth were worn off and obviously needs to be replaced. It looks like I have to remove the fan and I think the pulley from the lower left. Is this the AC compressor?
So My question is: What belt is this, what does it do, and can I run without it?
Sorry for the long rambling question and thanks in advance for the help.
