Real time: Attaching fuel filter
Durango, CO
Website
www.kindel.com
I'm replacing my fuel filter & fuel lines. PO had the fuel filter attached to the positive battery wire to the starter with a zip tie. I want to know where the fuel filter is *supposed* to be attached.
Also, in these pictures you will see there is a ground strap that is connected to the fame/skid plate but not on the other end. I assume this is supposed to attach to the starter, but I don't know where. Why would a PO disconnect this?
That filter doasn't look OEM to me, The ground wire which is the same color as mine on my '81 was attached from the bat. to the frame.
The fuel filter mounts to a metal tab by the rear leg of the batt. tray, visible in the last photo.
Get that METAL gas filter away from the battery cable.:eek:
The ground cable goes from a bolt on the frame over to a motor mount bolt on the BH.
The fuel filter is supposed to be bolted to a bracket behind and below the battery holder. The bracket can be seen on the bottom of your 2nd photo.
The battery negative cable should bolt to the outside of the frame just aft of the passenger-side shock mount. The engine and drive train are bonded to the frame with a cable that bolts to the frame below the charcoal cannister and to a mounting bolt of the starter.
HTH.
Todd Bull.
Done. I found the bracket and mounted the new filter to it. I bought new fuel line hose and created appropriate length sections and got it all together.
I could not remove my battery tray because the bolts are pretty rusty and the first one i tried to remove had the head snap off. So I did not hook up the frame ground wire yet. Works fine without it, but I want it hooked up correctly, so once I order a new battery tray, I will fix 'er up.
Maybe i'm confused. The wire in question goes from the frame rail to nowhere.
My negative battery terminal is attached to a bolt on the block.
So where does the this wire connect on the BH? Or is it supposed to go to my negative battery terminal?
Your negative battery cable should actually bolt to the outside of the frame just behind the passenger-side shock mount. Look and you will find a threaded hole there.
One end of the ground cable from the frame to the drive train should bolt to the top of the frame below the coiled brake lines (look below the charcoal cannister; I think it is also the bolt that holds the splash shield). The other end of that cable goes to the lower starter mounting bolt.
Todd Bull.
