love2fly
Flying the Mountains of the NW
Just recently I fixed an over rich carburetor on a 2F motor that was running rich from to high of a float setting and bad needle/seat.
Set mixture /timing /Idle to specs. Time in this over rich condition two hundred to three hundred miles.
Installed new NGK BPR4EY plugs set at .032
Drove 75-80 (max speed 50 mph) miles today and pulled plugs #3 and #5 to read condition.
I have read a lot of plugs before and these look to me as splash over or splash fouled plugs but never seen this before. I know the area around the valves inside the head are probably pretty crappy from the over rich condition that maybe causing this.
Treads - no color
strap - #3 ash gray no timing mark #5 one side light gray the rest darker gray, no timing mark
Ring - very light carbon and areas of complete nothing
Center - white with a slight tinge of tan and a shiny black stain on one side (presume the flash)
Can someone with plug knowledge confirm my findings or am I looking at some other engine condition.
Splash Deposits
Small islands of contaminants on the insulator indicate splash deposits. Replace with new plugs of the correct heat range. The use of fuel additives, carburetor and choke cleaners or other aggressive solvents before installing new plugs is the most common cause of this condition.
Thank you
Treads - no color
Splash Deposits
Thank you
