I'm in the process of installing a new radiator and an electric fan. Unfortunately, the PO moved the radiator mounting frame too close to engine, making it a little too snug for the electric fan, so I'm moving it further away to make room.
I want to disconnect one of power steering lines and reroute it for a cleaner install. When I disconnect it, is the fluid under pressure and do I have to do anything special when I reconnect the line other then just topping of the resevoir? I keep thinking there is something special I need to do like bleeding the brakes when doing a brake job.
Thanks!
Thanks!
