Re-fab upgraded 5speed support?
Charleston, SC
The Bell housing on my 4speed is bolt on. Is there an already fabricated bracket need for the upgraded 5 speed I am installing?
The H55F is designed to use thre piece crossmember under it to support the weight. The motor mounts on bellhousing are not used. Ideally the 10/82+ crossmember and L brackets that the frame are the easiest. The FJ45 and HJ47 each have their own L brackets. The other share the same one. I know modified 60 series and aftermarket version can also been used.
