Looks like you have an issue where the plastic mount for the flare is broken. All of the parts are available, but you may have a broken mount point on the flare itself. You can only be sure by removing the whole flare to look. My flares had several broken mounts but I was doing a lot of bodywork anyway so I just welded up the holes in the body and now I am flareless. I prefer the clean look of it. Mine is unique in having smooth painted quarters and fenders without flares.
I considered plastic-welding the mounts, but blew it off. You may want to think about it. If you do not want to weld and repaint your fenders and quarters, you may want to fix the flares. There are plastic-welding methods now that may fix them. They work very well. If you can fix the flares, you may be better off.
Factory paint is the best if you can keep it. I have had it both ways and I recommend factory paint as long as you can keep it up. It usually holds up best as long as it is not abused beyond repair. Repaint bodywork usually will not do as well. For that reason most owners will repair and repaint the flares as long as possible. They even replace them when necessary.
It is not that most members love the flares IMHO, but that removing them cleanly requires repaint and bodywork of much of the truck. It is just not worth the effort. It is simpler to deal with the flares and keep them. They look nice. My 80 required the bodywork in any case, and so the flares went away. It was rolled when I got it and most of the body was damaged from the start. So I took the flares off. It was easier that way. In your case it is probably not.
One possible way to correct problems has been described on this site often. It is to remove the flares and spray rubber bedliner at about the same contours on the sides, covering the body holes made to mount the flares. Another is to repair the flares and re-coat them with a rubberized bedliner spray from Duro available at Walmart and which dries to a dull rubber-like black look that hides flaws. The material is very durable and easily repaired when damaged. My door handles, mirrors, bumpers and rain gutters are coated with this paint. It is tough stuff! My front winch bumper doesn't get dragged in the dirt as much as most because it is shorter and higher than an ARB, but it had a fight with my garage door and won. The door lost paint while my bumper did not. (Or not much!) The rubber paint was tough and didn't give in. It has also met a couple of rocks. Repair is easy, just rub with scotch-brite, hold up some newspaper and squirt it up! I use it to coat plastic parts too. It is good stuff!
In short, I would try to keep the flares as long as you can. Spraying bedliner is practical, but makes for not the most attractive truck when you go to church on Sunday. Repainting much of the truck to get them off the right way is a lot of work. They tend to get the most of the trail damage, but if you can minimize it, it is easier to keep them. They do look nice. I like my truck without them, but that may not be best for everybody.
Having personally done the bodywork necessary to cleanly remove them, I would not recommend it to anybody who is not skilled and devoid of fear. It is easier to patch them up, glue them on, and paint them with rubber than to remove them and try to repaint the truck without them. It is easier to repaint them 5 times than it is to weld up the mounting holes and take them off.
Trust me, I have been there!
My truck was rolled and looked like a barn hit it from the left side and the top. Bodywork was an issue from day one. Yours has none of those issues. Don't start them. Fix the flares.
