RDB residual valve
high desert, ca
I always thought my brake pedal had a tiny bit too much travel. On closer inspection, I realized that my rear disc brakes (monte carlo, just like everyone else) retract too far. The fronts reposition themselves flush with the rotors, like they should.
So I installed a 2psi residual valve for the rear brakes and the brakes no longer retract too much. They are now positioned against the rotors.
Why would a residual valve be needed in this setup? I was under the impression that mounting your master cylinder on the firewall gave enough gravitational force to apply the minimal pressure on disc brakes, and that only drums needed a residual valve to keep that 8-10psi. My proportioning valve is not close to the MC, it is mounted to the passenger front frame rail, but is still above the brake calipers. Could a lower than normal position of this make a difference? Just confused.
The only reason why I ponder this is because after years, I have never got that damn brake system to balance right. The proportioning valve makes a big difference, but those fronts just don't get the juice they should.
Apparently disc brake caliper pistons require residual pressure to hold them in the correct position just like drum brakes.
Disc brakes only require approx 3 lbs pressure though. factory disc brake MC's have these.
My 74 MC had the drum residual valves front and rear. I took the front out after my DB conversion but I think I might need to install a 2-3 lb residual valve as you did.
I did four wheel disk conversion with a drum/drum master cyclinder, no residual valve, no problems (60 series front, monte carlo rear)
as a data point. I just swapped my booster out tonight and now have AMAZING brakes!!! I thought maybe I needed a resid valve for the front due to stopping issues, but as far as I can tell right now I'm A-OK.
I'll live with it a bit and post back if I do decide I need one
Go to my website in my signature line and the link on the green 55 will take you to my write ups.
Replace the master cylnder with 1986 supra or a 1992-94 toy V6 4x4 master cylinders. Disc brakes do not need a residual valve. The stock residual valve will apply too much pressure on the disc brakes causing them to over heat. The supra and toy truck masters work great and are bolt in inexpensive fixes.
