Rattling Noise When going over bumps?
Utah
Hey there, 2000 LX470 with 170k miles on it. Whenever I go over bumps there is a rattling noise that comes from front driver side. Stops if brakes are applied even a little bit. New brakes and have checked braking assembly thoroughly. Any ideas what the noise could be? Has leak below steering column u-joint, replacing steering rack to remedy. Also replacing universal joints along driveshaft.
Common to have loose heat shields make this noise, I know mine did - fixed with a big work drive clamp. Or maybe whoever did brakes forgot the anti-rattle clips? (disclosure: have not done brakes on my 100 to know if they uses those or not tho?)
