rattle
Get a helper and a dowel for the cold startup and you'll have 100% certainty on it. That should appeal to your Engineer side, eh??
DougM
cruiserman said:
... It's more like a light jazz beat against the timing cover that comes on after the fan clutch roar is reduced. It lasts for at least a minute, but I haven't waited around long enough to see how long it lasts.
It's an irregular tapping that gradually reduces. I'll see if I can capture it digitally.
Cruiserman... did you ever figure this one out??? Mine has been doing exactly what you describe for quite a while... the light jazz beat that lasts a minute or two after the fan quiets down. I have done a fair bit of poking around with a stethiscope and have been unable to locate the source. I have always chalked this up to being startup rattle, but your post makes me now think that it may not be if you have had startup rattle and this is something different. As per IdahoDoug's suggestion... mine has a new (<10K) AC idler so I am ruling that out for now.
Another dead thread . . . to get some closure, I never did figure it out. I pulled the AC belt to isolate the idler bearing, but in the mean time the weather got warmer. The noise is gone. While driving around with the AC belt removed, the idler adjuster bolt fell out, so I haven't installed the AC belt. I've got a spare on the other motor I think, and I was going to get to that this week since we're into the 80s now.
I'll repost later this week. Probably.
eric
edit:
Since you're in San Diego, it's probably not the cold weather causing oil pressure issues. I would look into the idler bearing(s).
Belts and the bearings of the components they service can make some pretty weird noises.
I'd try spraying some wd40 (NOT "belt dessing", IH8 that stuff) on the belts to see if that affects the noise at all.
Curtis
It is probably the normal start up rattle that most people experience. Mine noise came from that area. Which oil filter are you using? Swithching to the smaller style filter helps a good bit. I changed to the smaller Napa Gold filter and mine completely went away.
Hi. This is an old thread, but I wanted to find out more about this "normal startup rattle". What is this? My 62 rattles for 2-3 seconds after cold star-up. No other symptoms or issues. Sounds like thin metal rattling. Is this really "normal"?
