Rattle only when coasting?
NaterGator
On Gilligan's Island
Gainesville, FL
I need some advice from the gurus.
I've been driving on gravel/dirt roads alot recently, and I have noticed a persistent and annoying (to the point where I worry to varying degrees) rattle that seems to only occur when coasting, especially downhill. Washboard style road makes it much worse, but if you are on the throttle (and I believe holding a gear as well) it completely disappears.
Things of note: it almost sounds like two 4-5lb loose metal parts bolted together but rattling on each other. I was thinking potentially part of the brake system before I noticed the throttle behavior, now I'm pretty sure that isn't it.
Nothing has been done recently; I'm going to make some of the more obvious checks, but I was wondering if anyone has seen this before in these trucks; IE motor mount or something.
Thanks.
Is it gravel in the cat guards? I've got a rattle like yours that's from tiny left-over gravel from muddin' caught in between the cat and cat guard...annoying as hell in the drive-thru. Soundsa like you've got a larger piece stuck somewhere...
I don't think so.
I'm beginning to think it is coming from the birfs... like there is slop in the cage and it rattles when unloaded and the axle is jarring over washboard style terrain... when there is torque I hear nothing, when I am costing I hear it clearly with the windows down. It sounds like it is coming from by the wheel when I drive by a fence or something that reflects the sound up. I'm not positive when the last front axle service was done and the truck reads 122k on the odometer; however I have absolutely no clicking what-so-ever when turning, so I dunno. I also tried coasting downhill with all the lockers engaged and even when the front was wound up slightly from arcing a little I still got the rattle.
Needless to say I'm running out of ideas.
Is it doing it on all roads or just the washboard type? Mine was doing a noise that was somewhat similar and it was my rear u-joints in the drive shaft. It would only happen when I left off the throttle or when going down a hill.
check your u joints, mine did that some, and after a lil grease it was all better
