Random Speedometer failure
Buenos Aires, Argentina
Website
gustavocherro.blogspot.com
Hi !!!
The speedometer on my FZJ80 usually drops to zero when I exceed 60 kilometers per hour and then instantly returns to the current speed.
t does this randomly. For example, it will show 80, drop to zero, and then immediately go back to 80.
The same thing happens at other speeds.
Has anyone experienced this issue before?
I have searched through the archives, but haven't had any luck.
Thanks !!!!
loose or dirty connection somewhere in the speedo sensor wiring harness??
Hi !!!
Thank you very much!!!
It's one of the things I have planned to review. Hopefully, that's it, but I'm asking in case someone has had this problem before. Maybe I'm lucky and they can give me some guidance.
Cheers !!!
It's just your cruisers way of telling you to slow down 🤣
Hi !!!
Cheers !!!
Mine has an intermittent fault. I have a busted connector on top of the gearbox I am yet to replace.
Hi !!!
Apparently the problem is solved.
After cleaning Speedo sensor wiring harness, the intermittent fault did not come back.
A simple clean contacts solved it.
Yesterday I circulated about 50 km at speeds above 80 km/h and never fail.
Thank you all !!!
