NLFS Random Archived Classifieds
No Longer For Sale
Status
Not open for further replies.
Need a couple of Pig parts
I need a glove box door, preferably in decent shape. I also need the aluminum door sill plates for all 4 doors. Thanks, Hodag
80-series OME caster correction bushings
Need two Old Man Emu caster correction bushings for the front lower control arms for an 80-series. Only need two but in good, useable conditon. If you have them and just never installed them or installed them and then took them - I need two. Thanks in advance.
Mike R.
fj45LV rear springs are the same as fj45LBP rears.....and I "think" the 45 short beds, so that might give you some more choices.
nuclearlemon said:
i have no friggin clue what you're talking about, but is it a weatherpack connector? metripack connector? got any pics?
Here is a pic of a DRAC module (Digital Ratio Adapter Controller)
usually found on GM trucks, 89-94 s10s astrovans, and 90-95 full size trucks. I need the connectors and pigtails to one. I have the module already and plan to open up and modify to read the tire size and gear ratio I am running.
Thanks, I'll see if I can find it.
A 77 FJ40 has the black frame, dark grey short jump seat with out the fold down leg. The rear seat belts should be the darker grey color, but the lighter grey ones from the 79 and later years will work just fine also, they just won't match the fronts if they are still stock.
I think I have a set if Mark dosen't.
Josh
Paul_A said:
OK, shipping to 80013 is about $7.00, so if you want the shift lever, rod, pivot arm and gate let's call it $30.00. You will need to supply a few washers, a cotter pin and a shift knob. I am not sure if you will need the 4 speed t-case front engagement fork or if the old one will do, but I got that if you find you need it, too. Let me know.
When mounting a 3 speed case to a four speed tranny the front extension housing fork shaft is required (it's about 1 1/2" longer than the 3 speed one).
PTO Winch
I'm looking for a pto driven winch. I have the pto that mounts to the transmission. Just need a winch and a shaft if possible, if not, I can probably have a shaft made. Something around 8000 lbs. I live in Savannah. The closer the better.
Thanks
Status
