Rancho RS60612 Add-a-Leafs
Website
www.dccrusr.com
I have 4 Add a leafs that are used to lift a stock 40 1.5-2". This is enough to clear 33's with no rubbing. Here is what Jeff Zepp said about them on the LCML:
"Here's the deal: Rancho add-a-leafs P/N RS60612 contain two add-a-leaves, 3/8 center pins and 5/16 center pins, they are $60 each and you need two sets. Use the smaller pins. Jack up the frame and unbolt the u-bolts. Remove the existing center pins and then remove the bottom two stock leaves, the two shortest ones. Put the add-a-leaves on and clamp with c-clamps, then put in the center pins, replace the u-bolts and away you go. Notice YOU DON'T EVEN HAVE TO REMOVE THE SHACKLES OR SPRING PINS!!!! Yes, I'm shouting because these are what makes suspension work so much work. You will want shocks a little longer for full droop, but the bottom line is that this inexpensive lift will retain good steering geometery, ride is as soft as stock, run 33s with no rubbing and great articulation of road. Here's a photo of mine twisted up:
http://risingsun4x4club.org/forum/uploads/Rzeppa/B46_twisted.jpg
HTH and happy cruisin'!"
These are new, never installed, complete with both sizes of center pin. I bought them new, then plans changed, you know how it is. I paid just over $115 plus shipping for all 4, will sell for $100 including shipping to the lower 48.
PM me here or mail to dr@drmoulder.com
Thanks,
Fax
