- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Long Beach, Ca., April 1, 2013 –*Tenneco’s Rancho®*brand of performance suspension systems and shocks has*announced the release of an all-new long-arm*suspension*system (Part no.*RS66105B with black arms/springs; RS66105 with red arms/springs) for 2007-2013*Jeep Wrangler JK vehicles. One*of the world’s most recognized brands of off-road suspension components and*accessories, Rancho is manufactured and marketed by Tenneco (NYSE:*TEN). To*deliver [...]
To*deliver the ultimate steering envelope, added articulation plus increased ground*clearance needed during demanding off-road riding, the Rancho 4-in.*long-arm*suspension*system includes a front adjustable track bar that provides axle*center adjustment plus extended length, quick disconnect front and rear sway*bar*end links for increased*articulation.
The*new Rancho high-articulation front and rear long-arm design includes Rancho*exclusive, heavy-duty tubular-style front radius arms that add exceptional*strength and*stability to the system. Providing added versatility, the front and*rear upper links are adjustable, allowing for caster adjustment. Each kit*contains a rear*axle mounted track bar*bracket that restores proper track bar*angles.
The*new kit also requires a new integrated transmission crossmember (Part no.*RS886101 for 2007-11 JKs; Part no. RS886102 for 2012-13 JKs) for use with*the*long-arm kits*(RS66105/RS66105B). The Rancho transmission crossmember moves the*lower control arm mounting points up, adding increased ground clearance*for the*lower control arm.
Each*new Rancho long-arm kit includes front and rear coil springs, upgraded front*and rear bump stop spacers and front and rear extended length brake lines*to*accommodate*the increased axle travel. The new Rancho kit fits up to a 37-in.*tire.
Any*of the Rancho performance shock absorbers (RS9000XLs, RS7000MTs and RS5000s)*work with this system. All Rancho brackets are manufactured*using*high-strength,*low-alloy steel.
No*exhaust modifications are required when installing the new Rancho system on*2007-2011 Jeep Wrangler JKs. On 2012 and 2013 Jeep Wrangler JKs, the*system*requires*the use of a Rancho cross-over exhaust pipe kit (RS72003) or a new*front driveshaft. The Rancho cross-over exhaust pipe kit prevents contact*between the cross-over pipe and*the front driveshaft, allowing for optimal*driveshaft clearance and more suspension down travel than exhaust spacers.
The*system is compatible with the Jeep JK Electronic Stability Control System. Each*Rancho suspension system includes highly detailed, full-color product*installation*guides.*Some cutting is required during installation.
The*latest long-arm Rancho system for 2007-2013 Jeep Wrangler JKs is backed by the*Rancho brand’s limited lifetime warranty, see*www.GoRancho.com*for*additional details.
To learn more about the Rancho system*for 2007-2013 Jeep Wrangler JKs, please visit**www.GoRancho.com, contact your nearest Rancho dealer or call*1-734-384-7806. To*locate your nearest*Rancho authorized dealer, please use the “Where to Buy” tab at*www.GoRancho.com*to generate a list of nearby stores in your*selected*regional and other*online retailers.
The Rancho suspension and shocks brand is*one of the performance aftermarket’s leading brands. The Rancho brand of*performance suspension and shock*absorbers is*manufactured and marketed by*Tenneco (NYSE: TEN) and headquartered in Long Beach, Calif.
Tenneco (NYSE: TEN) is a $7.4 billion*global manufacturing company with headquarters in Lake Forest, Illinois and*approximately*25,000 employees worldwide.**Tenneco is one of the world’s largest designers, manufacturers and*marketers of clean air and ride*performance products and systems for automotive*and commercial vehicle original equipment markets and the aftermarket.**Tenneco’s*principal brand names are Monroe®,*Walker®, XNOx™ and Clevite®*Elastomer.
Link
Long Beach, Ca., April 1, 2013 –*Tenneco’s Rancho®*brand of performance suspension systems and shocks has*announced the release of an all-new long-arm*suspension*system (Part no.*RS66105B with black arms/springs; RS66105 with red arms/springs) for 2007-2013*Jeep Wrangler JK vehicles.One*of the world’s most recognized brands of off-road suspension components and*accessories, Rancho is manufactured and marketed by Tenneco (NYSE:*TEN).
Link
