Rams Horns vs Block Huggers
The Ghetto
I purchased some chrome block huggers for my SBC about 2-3 weeks ago and they still haven't come. I've heard a ton of good things about Rams Horns so I bought those instead.
I've got a huge exhaust leak and need new headers so I finally went Rams Horns. Haven't installed them yet though but should there be certain things as far as fabbing or whatnot to take in consideration. I've read a ton of posts and threads about Rams Horns, but I wanted to get the latest and greatest.:D
Bullet proof and will last a long long time..
Should be some of the best flowing manifolds out there..
Cheap
And they look good ceramic coated :D
Be sure and get Texican's cross over pipe. Don't have the part number, but do search with 'texican' as the lister and 'crossover' and you will find it quick. Will save you $200.
I used ramhorn manifolds, they were easy on fitment.
I initally had a pair of block huggers I was going to run, but the bottom flange was a hair away from the starter. All the older chevys I've had with headers always cooked the starter, and these header were further away. THe block hugger flange was way to close for my comfort zone.
Looks like you have the truck manifolds. It will be a tight fit to run the pipe inside the frame on the passenger side. I have done several small block convertions and it is too tight a fit for me, Makes it hard to work on anything not to mention the fuel line will be right beside it.
See if you can find a straight manifold for the passenger side that way you can run both pipes down the drivers side and widen them out once you get past the transfercase.
go under the oil pan with passenger side exaust and run both pipes side by side inside the frame down the drivers side and widen them at the rear. You will have to find a center dump manifold to go on the pass side though.
So, I went to pitch the idea to my muffler guy and he said that running it how I already have it with the muffs outside the rail wouldn't look bad at all. BTW, I got a center dump RH for the pass side. Thanks minter.
it's not that it looks bad, it's that it drags on the ground and your pipes end up dented like mine, but for a road rig go ahead.
Muffler guys like to run them to the outside rails because it is easier. It's better to keep them inside and up high.
