rams horn interference
spicewood,tx.
have a 75/40 that had a wornout sbc. so, built a new 355. this came with a AA motor and trans mount set up which seemed to be fine. well today i stabbed the engine. all looked great until i tried to fit my new to me rams horn manifolds! no fittee. original exhaust exited out the back on the drivers side and cleared the steering box. now the is interference. the engine centered in the frame.
i know i need to move the engine one hole to the right, but this seems to bind up the trans mount. i did a search and most people move the engine to the left. how is this possible unless you go to something like a sag p.s. set up? would really appreciate any sage advice. thx jim
IIRC, That is one reason some dont buy the ramhorns(steering arm in the way) I dont have them, and all is well with mine and I do have sag PS, Why did you get new exhaust manifolds? My only suggestion is to go back to the rear dump, But others may have more input.
Good luck
The manifold suggested by Downey off road for the driver side was the under-the-plug rear dump. The reason being the rams horn hit the stock steering box. You can move the engine forward or back and clear the manifold, but then you have clearance problems with the cowl or really tight on the radiator. Simple solution is to stay with the rear dump OR if you want the rams horn look pick up a driverside manifold from a late 70/early 80 camero or Pickup truck. There is a manifold that has the ramshorn look but dumps between the 5 & 7 cylilnder. There is some dipstick issues but can be worked out. You need to find the sparkplug shields also. The problem is even worse if you have the pu truck ps conversion. IT is a wider box. Stay away from over the fender headers. If you plan on using pu powersteering, the #5 exhaust pipe clears the box only by 1/2 inch. It goes directly over the return line and you cannot get the line into the box
This is the left hand side. Note the motor mount hole position. Also note the two header tubes rubbing on the steering box.
This is the right hand side. Again, note the hole position.
Here are a couple of pics of my 350. I'm using a Mark's of Australia conversion kit. This kit uses AA motor mounts. You can see how much offset to the right my installation has by counting the holes on my mounts. And it still rubs the header tubes on the steering box.
As for why you can't offset to the left, you need to visually check completely around your bellhousing, transmission and transfer case to find the culprit that's preventing you rom moveing the complete assembly over. You're not trying pivot the engine while leaving the tranny et al in place? That's incorrect, the whole assembly needs to shift left as a complete unit.
These tube headers, though they are designed to be snug to the block, stick out further than ram's horns. You should be able to clear with no problem if you can find out what in the tranny assembly is preventing it from shifting the the right.
update
thanx to all that responded on this issue. finally was able move aa rear a bit, too the max on my set up. also, with a bit of surgery, moved the front mounts.
now have 1/4 " clearance between the ramshorn and the steering box!
it is not the best solution, but best i could do. the rear ended 3/8 to the left of centerline [max with the AA propeler on mine]. the front is 1/2 to the right.
dont like it ,but it will have to do until i can go to sag or the other one which escapes me right now.:beer: :beer: :)
