radio issue
purchased a 1991 hdj81vx right hand drive. Ever since I purchased it the radio has not worked. In fact it does not even turn on, it appears that it is not receving power. Before I pull the steering wheel dash and trim off to get at it, I wondered why I cannot find the fuse for the radio. I have looked at the fuse block but there is not a radio fuse labeled. I have also looked at the Max Ellery repair manual but I do not see a fuse listed in it for the 80 series either, am I missing something. If so where do I find the fuse (most likely problem I would assume)
Thanks
I didn't need to remove steering wheel to get to mine (although it says to in my manual). I pulled out the ashtray to get access to two screws, and pulled out the small storage tray above the radio to get to two screws hidden behind it. Then I carefully pulled on the facia/panel to unclip it.
Mine is a 1997 80 series RHD.
I checked the fuses and there is continuity, but still no power to the radio. I have pulled the radio, can anybody provide me with information on which wires carry the power and which is the ground so that I can test that. Also if anybody knows what the voltage and amp feed is to the radio so that I can 'hotwire' to see if it powers up.
Thanks
