Radio Install
Mandeville, LA
I hooked up a Pioneer head unit yesterday using the two harnesses that are a direct fit for the LC. These two harnesses tie into 2 existing harnesses that are not used by the factory unit.
The new radio plays but when I turn it up the speakers short out. The unit still stayes on but no sound is coming from the stock speakers. This leads me to believe it is a speaker short.
I have searched and found that people have disconnected the factory amp behind the glove box. But in those threads people have also said by using the two hook ups that are existing bypasses the amp.
Another idea is to ground the stereo to the frame and not use the ground from the wire harness.
Thoughs?
Ok, Unhooked factory amp, the unit does not shut the speakers down now. Although now I'm getting cracking with moderate volume levels. Any ideas?
Cracking Fixed! Had a loose speaker wire. Probably from trying to jam the head unit into the tiny space.
You will still need to disconnect the amp. All should work fine afterwards.
Just installed my Pioneer NAV/radio last weekend. Disconnect the amp. It takes about 5 min.
X4 - Disconnect the amp.
Then, be sure to NOT connect the blue wire, as this will cause you problems (maybe that's your problem as well).
Edit: If you are running an after market amplifier, by all means connect the blue wire.
