Radiator Replacement
Honolulu, HI
Ok, so we've decided to replace the radiator. After all, it does spray coolant all over the front bumper. :)
We plan to order the 4 row from radiatorbarn.com, is there anything that we should take note of during the replacement? Any tips that will save us the frustration like we had on on our 4.0L Ranger water pump replacement? (We couldnt figure out where to how to get the fan clutch off/ what the gigantic wrench in the SST package was for)
Thanks
You won't need to pull the fan or clutch to replace the radiator in a 40. I can do it in 20 minutes with air tools, or less. Four bolts to the shroud, four bolts to the frame, the hoses, and it's out. Ditto back in.
x2.
You might as well replace the thermostat while you're in there.
When I bought mine (form Radiatorbarn) they plugged the drain and then painted the radiator. At first, it looked like they had purposely and permanently plugged it. Finally, after saying WTF about 20 times, I scraped off some of the paint and I realized that you can remove the plug and insert the drain cock from your old radiator.
Other than that it was pretty straight forward.
Ok, gotcha. Any idea on what temp. thermostat I should run? Something stock would probably work fine.
Also, the 4-row from RadiatorBarn will bolt right up?
AFAIK, you have two choices, 180* and 190*....but I could be wrong. Where you live, I would use the 180*. JMO
GL
Ed
Are the Radiator Barn radiators truly 4 rows?? I've seen others that make that claim that are not....
The one I got did have 4 rows but the quality was not as good as the three row that I had originally.
I have been running it for about a year with no issues plus there is a lifetime warranty.
when i replaced my radiator, i just decided to dive into it in my garage ( back when i didn't know anything about my truck) the hoses were soooo hard to slip off because they had been on there for years. I ended up having to cut them off with hedge clippers. haha. to this day the hose is still attatched to the old radiator...
thats the ONLY prob i ran into and im kindof a newbe to this.
oh and another thing i baught a stock replacement radiator (for my 2f that was swapped in when i bought it) and she runs really cool. no overheating and i drove this thing all day long on freeways and all over San Jose before this summer. sooo the stock ones are really good. a 4 row would be even better!
good luck
