Radiator Rebuild or Replace, 94
My 94 LC finally developed a crack in the top tank of it's brass radiator. I've checked with a radiator shop, and he say's he can completely clean the radiator, and put in a new top tank, all back together and should be like new again, for $100.
He also can sell me a good CSF OEM style radiator, and says it's just like the factory one, but cheaper priced, at $194.
Factory one will cost me about $418.
Trying to decide which is the best route to go.
I also am considering replacing the water pump, and maybe fan clutch since I've got 165000 miles on it. Those parts appear to be fine and no problems with them yet.
This is a 94 Land Crusier, and sure could use some good advice.
Thanks,
Bryan
P.S. I saw notes of upgrading the fan clutch, but not sure if that mod applied to a 94 since all the vehicles I saw talking about were later years. Something about a "Blue fan clutch and a modification" Haven't had time yet to read up on all the threads but have done a bunch of searching and reading.
Thanks for your help!
Shout out from Richardson, Texas.
After talking to a lot of shops that work on Toyota's, besides the dealers, I've ordered a new, CSF brass radiator, 3 row, which is made like the OEM one. This brand is said to be a really good quality aftermarket one. I'm getting it tomorrow, and I don't like the looks of it, will go back to Toyota.
Talked to more radiator shop guys, and decided not to go with rebuilding my old one. Last guy said when they crack, it's usually starting to develop rot inside the core, and its hard to clean out well.
I was also told that the water pumps on the LC 80 series are really heavy duty and last a long time. I will research this on Mud, and see when people are replacing those. According to the FSM, you take out everything except the pump to replace the radiator, so just a little more work and that's done.
Got 3 gals of Toy Red a/f, and new radiator cap. Hope to get her done Saturday or Sunday.
Thanks for the help.
Bryan
Bryan
It's a service item for the 500k mile service. :D
Wow, Thanks for that info Cary.
By the way, I got in on the HIR bulbs you were doing a group buy through Sterns? and those bulbs are still doing great. Wonderful upgrade.
Thanks
Bryan
Did you go with CSF?
I just ordered a CSF, it'll be here this afternoon... I will not, I will be in Tellico as a passenger...
After talking to more Toyota repair guys, I decided to just bite the bullet and got a brand new Toyota radiator. I was told by some that they liked the CSF, then by others that they've had problems with it. Two shops told me they really would recommend the Koyo as the only aftermarket replacement radiator they would use, but it was more expensive and is made of plasic and aluminum. I just said, F** it, I don't want to do this again, and the Toyota parts place said the original part is stilll available and is the same as they put in the 94 when it was first built, so that's what I'm using.
If you go by the FSM instructions, expect to take some time. I'm no speed mechanic, so I set some time aside for it. I've learned now from another mechanic that you don't need to remove the fan, belts and shroud, but just unbolt the shroud, and slip it back over the fan out of the way. Drain radiator and undo the coolant hoses where they attach at radiator. Take the battery and battery tray out. Take off front center grill, and I was then able to squeeze in a deep socket on universal and small extension to get those two nuts off the fronts by the head lights but they're a pain in the ass! Undo the two side radiator mount bolts, unhook the transmission cooler lines and tuck up high so they don't leak out, then you are ready to pull the radiator out the top.
There's some tips saying they unbolt the side bracket on the drivers side and put the old one back on the new radiator, but I'm not doing that.
I am also using new, Toyota Red anti freeze. Changed out the belts and hoses recently and the water pump and fan clutch appear to be fine for now.
Have fun.
Bryan
Bryan
Bryan,
When I flushed out my radiator, changed all hoses, etc., I didn't even have to use two gallons of the Toyota Red. The factory service manual called for a 50-50 ratio of coolant and water. Based on my reading of the forum, I also ensured that I used distilled water to mix with the Toyota Red. Where I live, the Toyota Red coolant is like $30/gallon, so was happy I didn't have to buy a third gallon.
I think you made the right move to go to the OEM radiator. Good luck.
Joe
Hello Joe,
I got three gallons of the Toy red A/F, and three gallons of distilled water to go back in place.
I've got it all loose, unattached, but having a hard time pulling the radiator out with the shroud still in. I was told that you can push the shroud back onto the fan as a big short-cut and time saver, but so far that's not working. At the rate I'm going, everyone in the neighborhood probably thinks I'm a union mechanic. Ha ha ha.
I think it calls out for 14 quarts in the coolant system, and that might be entire system.
Bryan,
It usually takes me at least double the time I see quoted by Mudder's doing projects......I usually end up cleaning up around the engine, walk around the garage muttering to myself, sit and enjoy a beverage and look out at the ocean....For me, working on the LC is more of a hobby, and supposed to be relaxing. If I'm in a hurry, I won't even start the next project.
Good luck getting it all put back together. At least, with regular coolant maintenance in the future, you'll have the peace of mind knowing you'll probably never have to put another radiator in the truck.:cheers:
This job is turning into a real PITA! I tried and tried to get the radiator out without taking off the shroud, and it just kept hitting on all the hose fittings on the bottom. I then tried taking the shroud off without removing the fan like some guys say you can do, and no deal with my 94 model. Started trying to do it like the FSM says, removing the belts and fan and pulley, and couldn't get the belts off. They weren't Toyota belts, and seem to small, and were cracked a little anyway even though those Gates belts were 2 yrs old. I finally started cutting all the belts off, and will put all new belts and hoses in there that are Toyota products. The fan clutch while dirty, sure feels good to me, with no leakage at all. There was no leaks at all around the water pump so I'm not removing it.
GOt to looking at my original radiator, and it's top and bottom tanks are plastic, but I thought they were brass? New Toyoto radiator exactly the same. Plastic top and bottom tanks. WTF??? Did I get the wrong model? This Toyota radiator P/N is 16400-66040.
I never could talk to C-Dan as we kept missing each other in calls, and I needed it now, so bought locally from Toy of Dallas. They are LC club friendly. Anyway, now I'm tired, frustrated, and not putting in the new rad. until I can verify that I got the right one, or if there's another one that is brass and better.
Bryan
P.S. doing this for fun ended a long time ago for me.
***** I found this so here's an update. Quote is from C-Dan******
"All factory 80 series radiators have phenolic (plastic) tanks. If you do not want plastic tanks you need to seek an aftermarket radiator."
Guess I got the right Toyota tank and it's got brass cores, not brass tanks. The plastic tank cracked right in the middle front of top tank, but it's 13 yrs old, so not bad for plastic, right?
Just to post an update, I finished this project today.
I went ahead and replaced everything with Toyota parts, new Radiator, Water Pump, Fan Clutch with blue hub, Hoses, Belts, Red anti-freeze and distilled water. I washed everything while I was at it, and cleaned a bunch. Still need to do a lot more cleaning in the engine compartment.
My big oops came at the very end, when I was checking for oil leaks and traced it to the valve cover. I decided to try tightening the bolts up just a slight bit, and was doing fine until I got to the right rear bolt by the firewall. That bolt was where most of the oil was and totally loose. I was reaching pretty far over, and using a 12" extension and a 3/8 flexable Craftsman wrench which is about 12" long, and I was gently tightening when the bolt just snapped. I was so pissed! I've never had any other bolts break on this rig, and it's going to be a pain in the ass to fix since it's kind of hard to get to. Hopefully I can drill it and use an easy out to remove this broken bolt. If it won't come out or just doesn't leak more there, I might wait until I do a head gasket replacement to fix it.
Wonder if that guy is still selling the head gasket DVD?
Yes, I've been told guys can do this in 1-2 hours, but not me. I took my time, and had some trouble here and there. Best way for me to eventually do this was to just follow the FSM and do everyone of their steps. Makes it a lot, lot easier by pulling the belts, fan, shroud, battery and battery tray. I sure won't waste any time next time trying to take shortcuts as this took more time and caused more stress than just taking off those parts.
Loved the quick and easy old belt removal. Quick f***ing with them and just cut them off. Loosen everything up after the old belts were out of the way if you plan to replace them. I already had a new set of toyota belts in reserve and got another new set to install. No more aftermarket belts or hoses for me. The belts were crap, and they were Gates but cracked after less than two years.
Thanks for all the tips and mental help I got here. Doing lot's of searching yeilded great help also.
Bryan,
you could remove the valve cover and that would probably expose enough of the bolt to grab w/ pliers or your fingers.
order a new valve cover gasket and don't forget to also reseal the 1/2 moon shaped pieces at the front of the engine too- they need to be done along w/ the gasket.
Radiator problems cause other problems. I wouldn't pick this as an area to try to save money. I'd go new OEM, especially if the truck is in otherwise good shape.
That's a good idea
Bryan,
Hmmm...that's a pretty good idea.
Thanks
If you must drill, use left-twisting bits. Chances are you won't need the easy-out that way. Normal bits will spin the bolt in farther if it's not rusted or frozen in.
-Spike
