Radiator Leak?
TEXASLAWMAN
TEXAS
Website
www.myspace.com
Today I noticed a small spot of toyota red under the front of my truck. After a closer inspection it seems to be coming from the top drivers side dosent look like its from the hose though. The weird thing is it leaks just a bit as its warming up then the leak goes away??? Then when the engine is turned off it leaks just a bit when cooling down. What gives???
Could be the upper tank is cracked. As it heats up it'll expand a little, closing off the crack. It won't get better over time....
Factory radiator? I know on my rad (aftermarket from PO) the brass caps are leaking on mine. Only when off and not consistently. Like its pressure related. You can try pressuring the system to see where the leak is.
Hit Autozone for free use of a pressure tester.
I just used one of the Autozone free rental radiator pressure testers to check my resent purchase over. I ran it up to 15 psi and got a couple of minor leaks that would of probably failed in the near future. You can also check your radiator cap for correct operation. Better to find it or force the problem now than have it fail in some obscure place later.
I generally do a few tests. Starting at cap pressure 8 psi on these I think. then step it up. Never take it over 15 or you may cause more problems than you find.
And if you are draining any of the coolant for any reason grab the Block Tester as well just see if there are any exhaust gases in the coolant. You need to have the level down a few inches to run this test. Free peace of mind (they even supply the test dye for free)
Its the factory radiator. I was on the rod when this started now that Im home it looks like it could be coming from the small hose right on the top middle. If its not that hose then its right there where the plastic top meets the metal. Is there anything I can do to prolong a new radiator for a month or so??? Like a glue??? Anyone have the 93-94 rad part # handy???
I would change out the hose to rule it out. I recently installed a brand new OEM radiator and didn't change out that hose and it leaked. Part number for radiator is 16400-66040.
Dont guess you have the part # for the hose too? :D
Well If anyone knows the part # let me know the dealership closest to me is having a hard time finding the hose.:doh:
Its not the hose. Coolant is coming out where the plastic top meets the aluminum in between the center top small hose and the main upper hose.
Common leak. Time for a new upper tank or radiator.
Can you get a new upper tank? Mine's seeping in the same place.
