Radiator Hoses
El Paso TX
Have anybody used the Goodyear Brand for Radiator hoses, are they more reliable then the OEM, if so how many mile do they recommend on the Goodyear hoses!
And since I am doing maintance should I replace the thermostat at the same time?
Thanks for any help!
Stockers work just fine and are cheap thru CDan. Yes - do thermostat at same time. Why not!?
Thank you, I was just wondering if the Goodyear hoses were just better, they are the same price as the OEM!
I bought all toyota parts and also purchased the Thermostat #90916-03117 and also bought the gasket # 16346-33020 it seems to be a rubber ring, now when I install the thermostat ring do i need to add some silicone so that I do not get any leaks?:confused:
No dont add any sealant, make sure that the thermostat is sitting squarely within that "grommet" (in other words it is not a just a gasket that goes on one side or the other of the thermostat it is like a grooved grommet where the tstat sits in the groove) and that the jiggle valve is at 12 o'clock. To answer the first question, I tried the GoodYear hoses on my old 4Runner, they worked well enough but not as well as OEM - they tended to kink ever so slightly no matter how the hose was oriented. You cannot get anything better than OEM for belts, hoses, filters, etc etc etc. :cheers:
Great this is the information That i needed, thanks alot!
Now for some work on the PHH!
They said it was difficult to replaced my gas filter and I did not think it was, I hope the PHH is the same easy!
The PHH is in my opinion really not that difficult to do. I thought the fuel filter required much more contortionism. Of course doing the PHH on the side of the road in poor weather, I'm sure that sucks, but doing it in your garage with a few fun drinks waiting is almost zen! :cheers:
