Radiator Flush
Chino, CA
Newbie here with some questions on flushing the cooling sytem (stock 77 FJ40, 2F, I don't think the rad is stock).
The only time I've flushed one before was years ago when I lived in an apartment that had a drain outside. Where do you guys do it so it doesn't just make a big mess with coolant going all over the place? I want to open the drain on the engine block, I can see that just getting all over.
Assuming I can figure out how to contain the "chemical spill", my plan is:
- Put in some of that Prestone chemical flush stuff and drive it for a while
- Flush everything
- Install new tstat and gaskets (previous owner pulled it to keep it from overheating)
It is cool to use one of those Prestone flush kits? Any tips would be appreciated.
Thanks,
Sean.
Use the prestone kit. You may find the engine block drain is blocked, they often are. Antifreeze is recyclable, and also it is biodegradable. Just needs to stay away from puppydogs and babies until it is broken down. Most auto parts places will accept it for recycle.
A clean coolant system is a happy coolant system.
