Radiator fan nuts
Murrieta, Ca.
The local dealer here in Temecula had a 25% off parts special and was a perfect time to get an oem water pump since the po's reman one was leaking. Anyway, new pump has 12mm studs instead of bolts like the reman. I just used some 12mm nuts and lock washers I had lying around to secure the fan to the pump. Is this OK? Or did Toyota use nylock nuts or something. Ill go get some if so. Thanks.
I believe that mine are factory and they are just a nut with a bit of a flange on the back side, no washers, no nylock.
