Radiator fan clearance
OK lots of good info on radiator choices as well as fan selection. Now, how much clearance is enough between the water pump and fan (when using an electric fan such as the Taurus)?
I have under an inch between the fan motor and pulley bolts. (71 FJ40 5.0HO stock radiator Tarus fan) Is this enough?
What are you running under the radiator bracket for dampening purposes? Stock rubber stuff long gone.
I would allow for trail flex. I don't think I would go less than 1 inch between the water pump and the electric fan. that may even be a little too lenient
Thanks for the input. I have re-visited a couple of other radiator threads and have noticed that a lot of guys are pretty tight to the radiator. I have moved the radiator forward and re-engineered my tarus brackets to give me anout 1.5 to 1.75 inches between the pully and radiator. I will be adding a rad support brace that ties back to the firewall in oreder to keep things still.
