Radiator Dissection!
LFD2037
TEXAS LEXUS!
Wax., TEXAS
Since a few of you were intrigued with my oil filter dissection I thought I'd do a radiator this time! Reason I removed it was my water temps had slowly been rising & got to 217* while idling. History:
Unknown miles (at least 20K)
Unknown maintanance
ADPI brand (I'm pretty sure it is)
Aluminum fins & plastic tanks
In the last 10K miles I flushed it 5 times
Green antifreeze from PO and that's what I use(d)
Distilled water
Bottom tank
Top tank
I'm pretty sure this is a leaf.
Looks like somebody used water straight from the Red River! (For those of you not familiar with the Red River, it separates Awesomeness from Oklahoma!!!!!)
Interesting design, looks to be single core? How thick is the core?
How are you flushing it? With enough water flow, more of that should have flushed out? My guess, the cooling passages in the motor also look like that. Rusty deposits can be tough to remove, often requires chemistry, CLR, etc.
Using the Prestone kit, flushing both ways. Total time of flushing probably adds up to an hour. I'm also afraid the coolant passages in the engine look the same way. It's a 2 row core. Probably can't tell if you're looking @ this on your phone, though. What's weird is, is that it doesn't seem to be rust. It seems to be dirt/mud/sand. After each time I'd flush it, & it'd run clear, I'd check the radiator fluid level a couple days later & it would have a red hue to it. I seriously think someone put water in it from the Red River, or similar water.
what are the tanks made of?
Plastic.
Looks like 1 tube with a divider, making it a 2 core I guess. Best pic I can get.
That's microchannel tubing, albeit with only two chambers. You can get it with different dimensions and number of chambers, depending on fluid viscosity and flow rate. Luvata Heatcraft makes some interesting products with it. MicroChannel Coils | Luvata
It sure looks like an APDI radiator. The material looks like a stop leak and pond water mix, which would be consistent with an APDI radiator. You have to have all that crud in there to keep them from leaking, on any car.
1.25".
So TxCruiser got me thinking. Is this crap I found in the bottom of the radiator a head gasket fix product? Do I have a ticking timebomb that could s*** the bed at any time or is it just junk in there? PO put whatever it is in there and I've put ~30K miles on it since I've owned it. The entire cooling system has been replaced by me. Only part not new is the Eaton fan clutch but I drained it and put 17K fluid in it. It roars at start up and can hear it get louder as I hit 199*. It'll hit 204 in a drive thru when it's 85*+ outside. So, is it just dirt crud or is it a head gasket/stop leak type product and I need to do a HG job on it?
I too was experiencing some higher engine temps, 194-204 during normal operation and was thinking about digging into the radiator. Before dropping the coin on the new radiator I replaced the water pump (190k on the Od) and put in a new fan clutch with 20k fluid. I'm hard pressed to get the engine temps over 190 now, even wheeling in the SoCal desert without a new radiator. :meh:
It could be core sand and flashing? When building competition engines we always used second hand blocks, as they were 'seasoned'. Despite the engines having seen over the years various flushing's, the rubbish that came out after the blocks/heads were 'hot tanked', often looked like that.
regards
Dave
How much crud were you able to flush out ?
I've done both of those things. Thanks.
I flushed the system about 5 times 6 months prior to cutting this radiator open. That's what was left after all those flushings. I removed this radiator to replace it with a KOYO.
