Radiator core support pictures
Plano texas
Hi, Even with my Toyota manuals I can't remember where all the parts go. If you can post some pictures of your 1991-1992 fj-80 front end with the grill off I would appreciate it. It's been months since I took the front off . Thanks, Mike
Ok, More specific. Horn and their mount picture. Wiring harness picture from fuse panel to battery ESP. Around the drivers side by Cooling fan. Thanks, Mike
Horns
Hi, That helps a lot .Does the wiring harness on the drivers side go next to the radiator core support or under and in it ? Mike
Thanks, How about the drivers side . I know it goes under the cooling fan . Does it go next to the drivers side headlight support or under the top part? Mike
Can I trouble you for another picture to the right of that one which shows the wiring harness , from the light support to the middle metal ,top section. Thanks, Mike
You cant see much the ac drier is in the way, it goes behind the drier to below the rad support
