The LC had some coolant leaks and so I had a trusted mechanic take a look and basically the radiator is busted. The mechanic quoted me $400 to replace it with a genuine radiator along with the thermostat.
Further, he said I need a major which includes:
Fluid changes (oil, trans, case and diff)
valve cover gasket
fuel filter
cap and rotor
plugs and wires
pcv valve
o2 sensors, both
Including radiator and the above, he said $1100. Doesn't include the hoses though, I might need that too.
I am kinda short on cash, but it appears I need the above them. I am sort of a DIY person, but at the same time, I don't have a manual for the truck yet.
Advice? Thanks!
valve cover gasket
fuel filter
cap and rotor
plugs and wires
pcv valve
o2 sensors, both
Advice? Thanks!
at best. The O2 sensors can be a pain due to rust, but it is not difficult, it just takes time, patients and muscle. Defintely buy OEM O2 sensors from Dan if you replace them. They are worth the extra money, the universal ones don't work. It will also improve your gas mileage if you are sporting a check engine light.
