- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Perfect Lightweight Jack Fits Anywhere FOUNTAIN VALLEY****DECEMBER**7, 2011* -**Specifically designed for the off-road enthusiast, the Hydra-Jac allows you to change a tire on most vehicles with aftermarket suspension lifts.**The lightweight 13 pound racing jack collapses to 37” allowing you to stow the Hydra-Jac in locations where other high lift jacks would never fit.**“We have put [...]Radflo Hydra-Jac Specifically Designed for Off-Road Enthusiast is a post from: RockCrawler 4x4 and Offroad Magazine
FOUNTAIN VALLEY****DECEMBER**7, 2011* -**Specifically designed for the off-road enthusiast, the Hydra-Jac allows you to change a tire on most vehicles with aftermarket suspension lifts.**The lightweight 13 pound racing jack collapses to 37” allowing you to stow the Hydra-Jac in locations where other high lift jacks would never fit.**“We have put a lot of technology in the building of this Jac,” said Glenn Classen, President of Radflo Suspension Technology.**“We saw how inconvenient it was to use the other jacks and how impractical it was to use a bottle jack, so we came up with this solution that has worked well in all the different applications that we have tried.”
The Hydra-Jac 22mm ram allows a load of up to 2,200 lbs to be hoisted 18 inches safely.**Usually no more than 4 pumps are required to lift the vehicle an inch off the ground.**To lower the vehicle safely, release the bleed screw at a comfortable rate of descent. It is light-weight, but the alloy materials have all the strength that is necessary to lift heavy off-road vehicles.**Like the Radflo Shocks, the Hydra-Jac is completely serviceable and rebuildable for a lifetime of service.
The Standard Length Hydra-Jac extends 54 inches retailing for $335.**The Extended Length Hydra-Jac extends 66 inches and has a longer body length of 48 inches.**Retail on the extended version is $360.**Great for uses on any vehicle including off-road jeeps with suspension lifts, race vehicles, trucks, trailers and UTV’s.* More information can be found at*http://radflo.com/hydra_jac.htm
Informative Videos on the Hydra-Jac by Radflo Distributor Snake Racing:
http://www.youtube.com/watch?v=O_ZCCjVL7nQ&feature=relmfu
http://www.youtube.com/watch?v=PnbOqJdc1cM
Radflo Website:**www.RADFLO.com
Radflo Facebook Fan Page:**www.facebook.com/RADFLO
Link
FOUNTAIN VALLEY****DECEMBER**7, 2011* -**Specifically designed for the off-road enthusiast, the Hydra-Jac allows you to change a tire on most vehicles with aftermarket suspension lifts.**The lightweight 13 pound racing jack collapses to 37” allowing you to stow the Hydra-Jac in locations where other high lift jacks would never fit.**“We have put a lot of technology in the building of this Jac,” said Glenn Classen, President of Radflo Suspension Technology.**“We saw how inconvenient it was to use the other jacks and how impractical it was to use a bottle jack, so we came up with this solution that has worked well in all the different applications that we have tried.”The Hydra-Jac 22mm ram allows a load of up to 2,200 lbs to be hoisted 18 inches safely.**Usually no more than 4 pumps are required to lift the vehicle an inch off the ground.**To lower the vehicle safely, release the bleed screw at a comfortable rate of descent. It is light-weight, but the alloy materials have all the strength that is necessary to lift heavy off-road vehicles.**Like the Radflo Shocks, the Hydra-Jac is completely serviceable and rebuildable for a lifetime of service.
The Standard Length Hydra-Jac extends 54 inches retailing for $335.**The Extended Length Hydra-Jac extends 66 inches and has a longer body length of 48 inches.**Retail on the extended version is $360.**Great for uses on any vehicle including off-road jeeps with suspension lifts, race vehicles, trucks, trailers and UTV’s.* More information can be found at*http://radflo.com/hydra_jac.htmInformative Videos on the Hydra-Jac by Radflo Distributor Snake Racing:
Link
