racing harness
Brisbane, Australia
can i put a racing harness on my front seats and also have a rear seat. do i need a bar across the roll bar to mount the harness on or can u mount them on the ground behind the seat. i want the passanger seat to fold forwrd so i can put people in the back how can i do this????
The ideal position is
anywhere between 5° below
and 30° above the driver’s
shoulder, as seen in part C
of Figure 2.
If the upper attachment
point falls significantly
below the driver's shoulder,
then a spinal compression
injury is likely to occur. In
an accident situation, the
shoulder belts pull down
and back on the torso as
they resist the forward
motion of the driver. The
resultant restraint force
compresses the spinal column
and will add to the stresses in the spine already caused by the force of the crash
impact.
On the other hand, if the trailing ends of the harness are too far above the shoulder
(greater than 30°), then two problems can occur. First, tension in the shoulder harness
is increased and undue stress is applied to the harness and its structural attachments.
Second, excessive angle will cause excessive motion. If the harness belts are too
far above the shoulder, they will provide little resistance to forward motion of the driver’s
upper torso. The result is impact with the steering wheel and the possibility of
neck injury. The shoulder straps should also be 3-6” apart behind the driver's neck to
prevent slippage off the shoulders.
