Wanted R151f with split case
it would probably be easier if we knew what you’re wanting to use the transmission for. Not all R151’s cross from one application to the next…
I’ll need to get a bell housing regardless to fit it to a 3.4 but it’s on an 80 chassis so the r151 from an hzxxx cruiser is what I’d prefer but if the prado r151 also has a split case then it’d work too.
With cases? And from what vehicles?
I’ve got 1PZ, 1HZ and 3L provisioned r151’s; however, based on your build plan I don’t feel comfortable taking your $… If you’re build platform is an 80 series you will need a bigger engine and a bigger transmission
It’s getting a 3.4 from a t100, 4Runner, taco, etc. which is the reason for the r151. The 80 series frame and axles are the reason I need the passenger drop transfer case. So a 1HZ r151 is what I’d like (lever-actuated is better) but I’ll have to use a different bell housing. If the pickup engine bay were bigger I’d put a 1hd/z in it probably but it just won’t fit.
