quick overheat....
quick question, i have looked a bit on this, but have not hae not found any good answers, that soothed my fears. i took my cruiser into the hills for the first time recently, i headed out of denver up hwy 72, just getting into the mountains i looked down and saw that my temp gauge was higher than normal. i pulled over as it got close to the red. i rechecked the fluid levels in the overflow, as i had done right before i had left, and it was good, started the cruiser back up after about 2 min and the gauge was right below the red, then dropped back down to normal while idling. continued the trip cautiously, and never saw the temp move again. what could have caused this other than a stuck thermostat? i did a compression check a few weeks before, and all cylnders werent 6lbs different. it has 160xxx on original HG on a 96. i am planning on taking the fam on a camp trip in a couple weeks, that is a little further away, and would like to make sure i dont have to ask the wife to push! any thoughts or ideas that may be common?
It should not have overheated, so there is an issue.
One common thing is a plugged up radiator. If you radiator has a bunch of plugged up tubes due to the sludge most of us have experienced on some level, then it may work during normal driving, but not be enough for climbing the hills. I think your radiator is probably fine if the engine cooled at idle.
Don't forget you can always turn your two heaters on in an emergency, if the issue is a lack of cooling capacity due to a plugged radiator.
If thermostat is not the issue and you have plenty of coolant, the water pump is still working, and assuming no headgasket or major mechanical issues, such as running too lean, I'd bet the radiator is plugged up.
Good luck.
Overheat
I had a similar problem soon after purchasing a 97 40th anniversary model for my wife. Before I noticed the temp gage, the a/c would stop blowing cold air. Soon after, I saw the temp gage above the half-way mark. At first I thought the problem was the A/C. After some logical deductions, the only item left to cause an overheat was the radiator. Took the radiator out and pulled the top off. The inside was almost completely clogged. If your pump is working, I will bet on the radiator. Given the age of the vehicle, it is a small price to pay for a lot of peace of mind. The work is pretty easy. I had mine changed in under 2 hrs. Total cost - $300.00. A whole lot better than replacing a motor.
