We are talking about two separate, but important things.
There are RP (residual pressure) valves in both outlets of your drum brake master cylinder. The RP valve is not needed for the toyota front disc brakes, so it should be removed.
There is also the issue of a proportioning valve to reduce the hydraulic pressure to the rear drums, because they actually work too well in comparison to the front discs. The stock setup on a disc brake truck was a fixed prop valve that mounted right on the bottom of the master cylinder. If you don't have the stock valve, then it will be necessary to install an inline prop valve from Jeg's or Summit. Then you will have a nifty adjustable valve to play with depending on tire size and vehicle load. With no prop valve, the rear will be squirrelly under heavy braking, especially when cornering without any weight in the back of the truck.
