quick fix for starting problems
Plano, TX
I'll try and do the cliff notes version here.
I was having trouble starting. Nothing consistant it would work fine 10 times then not start the next. Narrowed it down to electrical and then realized something interesting. When you turned the key and all dashlights lit the truck started. When only the seatbelt lit, nothing. After a few hours and some help from Jon (80's cool) I replaced the fusable links. Worked fine for 2 months and then started to do it again...Crap. Once again out came the test light and FSM diagrams and couldn't get any results. Previously I had pulled all the fuses and they were fine, I replaced the EFI relay, couldn't figure it out. I then decide to retest the fuse block next to the steering wheel and low and behold I touch the IGN fuse and discover that it's loose. Never found it before because I was pulling the fuse totally out not messing with it with the ignition on.
Basically the prongs had gotten spead out just enough to let the fuse back out slightly over time. Couldn't believe it.
Sounds like you've got too much heat in that socket. I've seen people where they'll blow a fuse that is 15 amps, put another 15 back in only to blow it. Then they'll stick a 30 in there and all will work but the load of the short is causing the socket to get hot. Is it the right fuse for the socket? If it is then you could be at your threshold of amperage for the fuse, ie the fuse is 15 amps and your at 14.5 constantly. Just a thought....:idea:
I'll check, it physically is loose though.
That's a good sleuthing job if I've ever heard one. I would have checked the fuses last, just so I could waste money on a new ignition, starter, and battery.:rolleyes: Then again, I love to make simple tasks as difficult as possible.
TK
LOL kinda like me trying to find the best deal on a new ECU!
