Quick CDL light question
Long Island
On my 91' 80, the CDL certainly works, tested it on dirt. But the light does not illuminate at start up or when engaged. I have read the threads here, and searched to the end of the internet. It is possible that it is just the bulb, but my D light works as well as all the others. So, besides diving into the dash to change a bulb that might not be bad, is there another explanation (read easier to fix), that I should look to first. Not a big deal, but I'm pumping $ in to this rig, and the more I do, the more I'm obsessed with making everything work as it should.
Excerpt:
What the Factory Service Manual Doesn’t Tell You
The previous CDL tests are all that’s outlined in the FSM. The following CDL diagnostics are not in the FSM and are summary of various resources found on the Internet.
Test DIFF LOCK Indicator Light and 4WD Indicator Switch
The DIFF LOCK indicator light not working (when the CDL switch is on or when shifted into 4L) may be that either the dash light is burnt out or the 4WD Indicator Switch is defective. To test, with a paperclip in hand, crawl under the right side of your Land Cruiser and locate the 4WD Indicator Switch. The 4WD Indicator switch is located on the top front housing of the transfer case. Remove the harness from the switch and jump the terminals on the harness with the paperclip. With your ignition in the ON position, your DIFF LOCK indicator light should light up. If the DIFF LOCK indicator does not come on, you most likely have a bad bulb and it will need replaced. If the bulb is fine, you will need to remove the 4WD Indicator Switch and either free it up or replace it. I would first try to exercise, lubricate and test the switch before replacing it. Once the switch is removed, place the switch in a vise. Check the continuity between the terminals. When the switch is open, there should be no continuity and of course when closed (depressed) there will be continuity. If the switch is sticky, use some WD40 to clean and exercise the switch. This may or may not work but is worth a try before spending money on a new switch.
Excerpt:
Bulls eye with the reference. Thanks.
