I bought a set of gaskets that go on the back of the axle hubs and are held on by " oil splash ring" ..? Can't remember the exact name, well if you've pulled an axle off a LC you should know what I'm talking about.
So the question is should I replace these gaskets? I'm a but concerned about keeping gear oil out of my brakes as this is the whole reason I've replaced the bearing and seals. The problem I'm having is removing the wheel studs. I gave em some heat and wacked em with the "big daddy" hammer NO LUCK. I put the in the back of my truck and will most likely have a machine shop or maybe a brake shop press out the studs.
If I do get these studs out, will they draw up ok when I tighten the wheels?
