The History - I have a '99 LC with 88k miles. It gets terrible gas mileage, 11 mpg. However, about a week ago, I got a CEL so I checked all hoses and connections. I found one vacuum tube disconnected under the plastic engine cover. I reconnected that hose. SO then I disconnected the battery to see if the CEL would go out and stay out. It did not, it came back on after about 50 miles. I then went and had the code read and they said it was the bank 2 sensor 1, heated 02 sensor. Also, I have not changed my driving style one bit or have used any different gas octane, I always use 92 octane.
Thats the history, now for the questions.
My gas mileage has dramatically increased to like 12.6 mpg.
1. Is this because I disconnected the battery and the vehicle has not learned to return bad gas mileage yet?
2. The O2 sensor is not functioning and effecting the gas mileage. This is a stretch. I am thinking no way.
Now for the weird part, can a OBD2 reading give incorrect information. When I was under the LC looking for loose connections, I came across a strange thing. A little grey connector was disconnected, down by the axle on the bank 1 side of the vehicle. I could not figure out where it connected too so I left it. After referring to my Repair Manual V2, it appears to be the other end of a o2 sensor but it is on the wrong side of the engine. I will check it closer tonight now that I have a clue as to where it is suppose to be connected. I wonder if the Toyota dealership disconnected this when they replaced the cv boots on both sides and that is causing the CEL.
I will let you know what I find.
uzj100
uzj100
