Questions about engine swap(long)
Pa.
I'm getting ready to pull my tired,knocking 1/74 F engine. I'm putting in a rebuilt 6/75 2F with the 4 speed.I'm switching the complete drive train.The 2F has been slighty desmogged,but still has the vsv box,and vacuum lines hooked up.It also has the stock exhaust manifold that seems to be in good working order.I've done a search,and got most all the info I need.I just want to cover my ass before I start this.
I have a '74 carb rebuilt by Jim C. with the vacuum port for my '74. I also noticed this '75 carb on the new engine has a (I'm guessing),vacuum port in the same spot as the '74,but capped off.It's a June of 75 carb.I also have a '79 dist. setup in my '74 engine. I'm putting that setup in the new motor.
My questions are,should I just use my two piece sor header,and get rid of all the emissions stuff,or use the stock manifold,and plug all the emission lines and holes.Will the '75 carb work,using the capped off vacuum port as my advance with no problems?I'll be using the '79 dist. setup. I've seen where a couple people have used the older carb on the 2F engines. I know this is long,but thanks for any info.
Bob
If the stock manifolds are in good shape, I would run them and remove anything that you do not need to operate the vehicle.... ;)
Mountainman, I just finished this same swap and will post about the things you think will swap, but don't...at least without some effort. Do it anyway.
Ed
EDIT......I run a '74 carb on my 2F. And a 2-piece SOR header.
Thanks Ed,I've been following your posts,and plan on doing a lot of the same things.
