Question re Fog Lights for ARB Bumper
Oklahoma
Installed ARB bumper and my stock fog lights will not fit.
Would like to install a nice set of lights in bumper and use existing harness plug.
Any suggestions would be appreciated.
what year and model of vehicle do you have?
I have installed a couple ARB bumpers with IPF lights using the stock harness, but you can't use the OE connectors (you have to cut them off and use the ones included in the light kit). I don't believe there are any lights that will accept the OE plugs.
Yea - you won't have much luck finding a replacement that plugs into the existing harness. But once you find some lights that will fit the hole in the ARB, you can cut the connector off of the OEM fog lights, and solder it to your new lights as long as the wattage draw is comparable. If you are running 100w fogs you should probably wire it up with the wires and relay that come in the package.
