Question for weekend project
Central Florida
So this weekend i'm taking on a few things that need attention on my rig.
1. The new antena mast insert
2. Replacing the valve cover gasket. Should i use high temp sealant a long side my the rubber gasket?
3 Replacing the EGR valve. Should i use hi temp sealant on that also?
4 Distributor O-Ring. I s this something i can scew up easily should i take it to an expert?
RE: #2
I would only use a little RTV to hold the valve cover gasket inside the valve cover, makes it much easier to install.
I wouldn't add any to the sealing surface between the head the gasket though.
If you're doing the valve cover gasket, make sure you go ahead and do your PCV (easier to fish out busted grommet pieces when its off) and replace the spark plug tube gaskets.
