Question for the knuckleheads...
Calgary, AB.
I've read and read and searched, still have one quick question:
For the front knuckle rebuild on my 1991 HDJ81, how much sythetic Mobil Red grease do I need for the bearings, and also how much Valvoline synthetic moly grease do I need to pack the birfs and knuckle cavity?
Just want to pick up supplies today and was hoping to hear from someone that has just done this service so I know how much to buy...
Also, from what I've read these are the recommended greases, am I correct? And it is recommended to re-use the factory shims correct?
Just hoping for a quick answer to set my mind at ease, I appreciate it...
Greased up
I just did the front last wekend and I used over 3 tubs of moly. and one tub of wheel grease. So I had 4 moly and 2 wheel grease on hand. ALso needed diff fluid as well. Plus a case of paper towels.
Good luck!
One tube of multi-purpose grease for the bearings and just under 3 tubs of moly is what I used last weekend. I probably could have got more moly in the knuckle so buy 4 to be sure. The greases you mentioned would be perfect selections. I used regular high pressure lithium grease for the bearings and regular moly grease for the knuckles.
Hey guys, thanks a lot for the replies... now off to spend all my spending money. Yahoo...
You'll need more paper towels.
-B-
I used about 4 tubes of Valvoline Palladium (from Napa, had to buy a case of 10), and two tubs of Lucas wheel bearing grease (any Canadian Tire).
x11 on the paper towel.
