Question about water in intake.
Cincinnati, OH
I went offroad and went through a mud pit. I got out of it and my engine stuttered for about 1 minute. I went through it kinda fast so i'm thinking a little water got in the intake. Do i need to worry about anything?
im thinking water did not get into the intake but rather got a ignition part wet for a brief moment... but pull the filter out and inspect it see what you find
how’s your car running now?
most probably that shudder was water getting on/around ur distributor and spark plug wires and causing some type of short... hence after it dried out the engine will be back with normal.
If you were to get water in the intake, small amounts are able to be diverted and or absorbed by ur filter... anything that would make it in your combustion chamber will cause way more damage then a little shudder... at the least you would have major power loss and ur exhaust would have smelled really funny....
my opinion is that you had some water land on the distributor and or surrounding areas causing a temporary short....
runs as well as it did before i went wheeling.
Then you have nothing to worry about..... just a heads up.... your intake sucks up air from inside the passenger side front fender... so if your just playing in the mud, try to throw your drivers side in the deeper water and or mud. In water crossings I try to be more careful when its on my passenger side bc I know I have the intake in there...
