Question about tire tubes
charles town wv
About to switch out my old tires on my FJ that has the OEM 16” lock rims and they have tubes.
I noticed when I pulled the tubes out the tube states 7.00 15AS.... is that ok seeing how my wheel should be 7.50 16??
Thanks for your help!
I worked in a truck stop tire shop. This was back when 90% of the trucks used tube type tires on lock ring wheels.
Some of owner/operators preferred to use an inner tube that was one width size smaller than the tire. e.g. use a 9.00 x 20 tube in a 10.00 x 20 tire. This was done to reduce the chance of the tube being wrinkled which was a sure way to cause a leak.
In your case a 7.00" tube in a 7.50" tire is OK so long as the tube is not borderline undersize for even a 7.00.
However, your wheel diameter is 16" and the tube is for a 15" wheel.
This application would stretch the tube both in cross section and diameter - maybe too much.
I'd find some 16" diameter tubes. They may be sized for 7.00 - 7.50 and that's OK.
There is another parameter for inner tubes - that is valve stem "offset" and style (length and whether it is or can be bent to point to the outside). This is based on the design of the valve stem slot in the wheel. I cannot help you with those details.
Tube type wheels like these need a "flap" between the ID of the tube and the OD of the wheel. Those are sized to the wheel. If yours are wrinkled, cracked or caked with embedded grit you ought to think about new flaps.
A good tire shop ought to be able to help with tubes.
I was recently tube shopping for the 16” lock ring wheels on my swamp trailer and was surprised that some tubes are listed for multiple diameter wheels.
Such as these. >>> “TUBES”
